Hello,
i have a strange behave in my plex.
I have PMS running on ubuntu.
I have 1 plex user and 4 managed user, 1 for each son and wife.
I use Apple Tv Plex client.
Sometimes it happens that my son is looking a serie tv episode and stops plex client without stopping episode.
If after this i run plex app on the same apple tv with my user, i have in dashboard that episode as if my user was watching it.
IS there a way to solve this?
Is this a PMS bug? Or maybe Apple tv app bug?
Uninstall trakt plugin…
There are settings that need to be completed within trakt if you need it… not sure which as I have not used it for quite awhile.
Tnx for your unswer.
Did you experience the same issue?
Are you sure that the responsable is trakt plugin?
That is the only plugin i really need
so that i can keep my 2 servers sincronized.
Thanks @OttoKerner… I knew it was out there somewhere.
@OttoKerner said:
See FAQ Scrobbling · trakt/Plex-Trakt-Scrobbler Wiki · GitHub
I already had that config, but it doesn’t see to solve the problem.
Does the unfinished episode also appear when you look (with your user account) into Plex Web?
If not, I assume it may be an ATV bug.
I don’t know as i don’t use plex web to watch, i only use ATV, and it doesn’t happen always but it seems only when my son turn off atv without stopping movie and after that if a login with my account in ATV.
