Plex Version 1.18.0.1944 Live Tv stopping after a few minutes and Pixellation started to happen again on public release
Server Version#:Version 1.18.0.1944
Player Version#:6.4
Oct 15, 2019 09:52:11.147 [3724] Error — [Transcoder] http://192.168.0.146:34400/stream/c9630ddd072f5414a00a16c9ab2446e2: I/O error
Oct 15, 2019 10:01:16.026 [2988] Error — Error issuing curl_easy_perform(handle): 28
Oct 15, 2019 10:01:16.026 [2988] Error — DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2019-10-XJYJ-JVHZ2K:20, marking as dead.
What TV tuner are you using? The I/O error suggests that there was an issue with the communication between your Plex server and your TV tuner. Also, have you rolled back to whatever version you were last using to confirm that the issue is specific to 1.18.0.1944?
im using xteve plugin tuner and i rolled back to version Version 1.16.6.1592 and it fixed the issue so is a problem with the new update also the tv guide on windows app is not working with Version 1.18.0.1944
I don’t think I can help since xteve is a different animal, but I’m seeing some other non-xteve reports of similar issues so perhaps someone will jump in. I haven’t experienced this (yet) myself.
The issue with Live TV and the Plex Windows app is being tracked here
