I recently switched from a Roku Ultra to a Shield Pro and I am having the same issues as this older post
Has anyone figured out any solutions to this? I have done lots of research and it seems like no one has received a straight answer on how to fix the stuttering issue.
Thanks for the reply… I really hope someone can get this fixed. Frustrating when you pay that much for a device and the one app you use the most does this
The Shield is my Go-To player.
It’s top tier in everything.
To hear someone is having problems just doesn’t fit with what I know.
(I push it to 180 Mbps DirectPlay and it never flinches)
I’m joining in here because I also have these frame drops.
Unfortunately, they are difficult to reproduce because they are completely random.
I can watch the same episode 5 times and 4 times everything is fine.
I haven’t had the problem for very long and generally everything works great, but sometimes it’s as if the file is running at 10fps… like a hiccup, usually it recovers on its own
At least for me it only occurs with 4K material… regardless of whether it is HDR or SDR
-Client is a Shield 2019
-Server is my old Shield 2017 via gigabit and the files are on an 8TB SSD on the USB port of the shield. -Streaming is on maximum, subs auto, framerate match on or off doesn’t matter
TV is an S95C, shield via HDMI into the TV and then via eARC into the soundbar
everything is Direct Play btw… no transcoding at all… (all HEVC files)
It doesn’t matter whether it’s a 10mbit file or a 100mbit file… it looks to me like the bitrate doesn’t really play a role.
It is a bit annoying, but not a big deal for me.
A fix would be nice though
Sorry if it sounds weird, I used google translate for this text
Finally home - checked the settings like you mentioned… everything is set like you stated. The only difference was the passthrough - mine was set to disabled - should it be set to HDMI?
Also, should I change any of the refresh rate switching?
Sorry, but if the refresh rate switch to off, and the Shield is set to 4K59Hz, 4K60Hz or 4K50Hz, but the Movie is 24Hz or 23,98Hz, is must be look like stuttering.
Everytime the Refresh Rate Switch should be “ON”
Update - I changed the passthrough to HDMI and after 30 seconds the shield would just turn off. Disabling the passthrough allows it to play without turning off.
After this the issue still was happening. I changed the refresh rate switching to on and seemed to help… still there but not as bad.
