No offence I don’t think you’ve read all my messages in this thread.
I have just now tested the same movie I played 3 times on my shield via Plex in the earlier test
Shield (ethernet) = 3 runs dropped 4+ frames each time
Phone (WiFi ) = didn’t drop 1 frame
While the phone test was running my shield was also direct streaming via the Plex addon In Kodi , no dropped frames. 2 concurrent streams , no frame drops on either device, for me this is not an internet issue
Plex on my shield also doesn’t drop frames when passthrough is disabled either
If it was an internet issue wouldn’t it show dropped frames here?
It only drops frames with passthrough ,
I speak of Kodi because from the Kodi forums they went through a very similar issue ( for me it’s likely linked ). I’m using the Plex plugin via Kodi as well.
I’ve said before that I believe it’s due in part to how the device plugged into the shield deals with the passthrough as well.l hence why I think it’s doesn’t affect everyone
That’s why I asked for you to test hdmi passthrough directly to the c1
If I switch off passthrough, I no longer have truehd or dts:x. The shield also cannot decode true HD or dts:x. A test without passthrough would transcode the film or I would have to choose a different soundtrack without HD sound. In addition, with plex v9.28 everything works smoothly, even with passthrough.
My server is local. I just tested with the latest Beta version (10.21) and was seing occasional dropped frames, as I have with all versions after 9.28, but unlike your test, the nerd stats weren’t showing any dropped frames. I saw 4 drops in the first half hour of playback. I still think we’re both seeing a passthrough bug, just differently since we have different setups.
I’ve mentioned elsewhere that I’m running Shield v8.2.3, but just wanted to re-iterate here.
Run 1. - 9 dropped frames
Run 2. - 5 dropped frames
Run 3 - 7 dropped frames
Plex beta app 10.22.0
Run 1 - 0 dropped frames
Run 2 - 0 dropped frames
Run 3 - not done.
I haven’t had time to do a 3rd run but already seems like to me whatever the issue was is now fixed for me.
Before I couldn’t watch this movie on 10.21 without at least 5+ drops each time , on 10.22 I’ve had no drops in 2 runs !
I urge the others who had similar issues to try this build and see.
I tried my stocking and async movie and what should i say, the 10.22 is the new 9.28.
It played fine without hanging to be async and with 0 dropped frames.
I played another movie, also 0 dropped frames.
Whatever the Team did, they did it right. I think, after over one year, it is now fixed with 10.22.
When will this be available to everyone? @ChuckPa above said it had to be installed with adb, but last time I sideloaded something on the shield (because of another plex regression) it was done with a file browser and the remote. Is that possible here too or is this build different in some way?
Side loading with a remote? Not since a Looooooooong time ago.
This will be available as normal installable package after the QA and release process finishes.
I don’t think it will be too long.
Using an “Alpha” build is not for the noob / neophite .
One does need to understand both process and risks --AND-- how to uninstall if there are any issues.
If you can download the APK from the link provided, you can then copy it to the Shield via your network and use a file explorer app to install. That’s how I test an occasional beta build, as I don’t want to actually sign up for them.
Yeah, this or with a USB stick is how I always do it. I was surprised to see the requirement to use adb to do it so I was just wondering if this was special or something.
