Server Version#: PlexMediaServer-1.22.3.4392-d7c624def-x86_64
Player Version#: web (using latest Chome 64-bit)
No library on the home screen retains it’s customizations any longer (last two versions of server installed on my QNAP).
Most importantly, switching from “Recommended” to 'Library" (which I still wish was FORCED op;tionally by a server-side setting). “Recommended” is useless in my scenario as always. NOT keeping the new setting as it did until the last two updates is unwanted new behavior.
- Select “Documentaries” library
- Select “Library” view on the bar at the top
- Switch to a different library
- Switch back to “Documentaries” - it is back at “Recommeded” view (same for every Library)
This combined with the fact that it REMEMBERS the last selected subfolder in every Library, is unwanted functionality.
