Correct, do it from Apple app store or from
There is nothing in Applications folder where you tried to launch?
No, there is nothing Plex in the applications folder. Also, what do I search the App store for? Plex does not show up
Looks like itās not there
OK. Downloaded from Plex.tv and the exact same stuff happens - I open the zip file and then I run the Plex file. It asks if I want it to move itself to the applications folder. I say yes and it doesnāt do it, so I try that again and nothing, so I move it my self and then try to open the app and the same thing happens.
Go to Privacy and Security scroll down and allow to Security
That was already selected
Try opening the installer again
There is another message below the Allow Applications fromā¦. It says my current security settings prevent the installation of system extensionsā¦.. is this an issue?
I forgot about this security issue. So Sorry.
Itās all good
Itās all goodā¦. meaning I donāt need to do this or I doā¦.?
Apple have locked down OS even more now. A super Gatekeeper if you like
Do it please
funny thing is, my M4 does not have this enabledā¦. regardless, I will be able to do this while still taking to you. The good thing about running 3 independent commuters at once!
All Cool
If you selected Reduced Security, select any of the following options, if needed:
Allow user management of kernel extensions from identified developers: Allows installation of software that uses legacy kernel extensions.
I had to do this on my M2 pro which I sold and bought a M4 Pro, super unit, love it so much. A beast for Video
OK. I did what you said and chose the following
Now I am downloading the program againā¦..
You may see a Allow prompt in Server settings/ Privacy & Security/ Security when you receive a Error on Desktop. Close error first
