That is fine - if your local network is on 192.168.1.x subnet then that is private network. But if you had defined a local subnet as being for example 50.20.12.x then the server local IP address would be a WAN IP and would need authentication and internet access
If the server is claimed already and signed in to plex.tv then access via localhost must authenticate and plex.tv access is needed to authenticate. What I do on my holiday home is use my iPhone as hotspot and get the server to access the internet via the hotspot (in fact i have a client router for the local network and it is the client router that connects to my temporary hotspot) and can then get to server settings and sign it out of plex.tv. Once server is signed out, you no longer need the hotspot. The alternative is to delete the settings keys i mentioned.
Well, our holiday home is much further away from civilization, as I said, thereās no stable internet there. At all. There are still a lot of places on earth where you canāt even get decent 2G connection, let alone 3G or 4G. And often thereās no 2G, 3G or 4G signal available in the area at all, depending on weather conditions and cell tower load and I donāt know what else. The fact is - weeks without any kind of internet. Itās good, nature and all, but itād be nice to watch a movie now and then.
My family also uses unlimited internet plans on our phones, but one downside of it is that you canāt use it as a hotspot anyway, operator blocks it.
Is it required to claim the server for any features to work?
Iād like to propose a possible solution to simplify this process. If server detects that thereās no internet, and that youāre connecting from LAN - give user an option to automatically comment-out or turn off those settings, instead of requiring us to edit those manually on the server. Would it be hard to implement?
That would bypass security and if you allow it then, there might as well not be any authentication on local network or localhost - but the decision was taken that there would be.
If adding your local lan (or the private ips of your plex clients) in the plex server settings and allowing insecure connections doesnāt work for you, you may need a different solution.
essentially the plex team has consciously decided to require online authentication, both for security and no doubt to manage the plex pass features, and to monetize the user base via the recent news and web shows additions (and probably even more future related āfeaturesā).
It has gotten difficult to use plex server in a completely offline manner.
There is no āofflineā mode for the server (like there is for clients).
That is on purpose.
For your use case, a remote/vacation/country home without consistent (or any) internet access, I would simply suggestion you pursue a different solution, perhaps such as Kodi, which doesnāt require any online authentication to function.
Of course, because kodi is a āthickā client, it may take more resources for playback than having a separate plex server and using a plex client for smart tv or appletv or whatever.
But with kodi you can have multiple user profiles which will allow for different peopleās watching where they left off.
There are also other alternatives out there, which may or may not be suited to your particular situation.
