I’ve been having an issue retrieving metadata from PLEX server after the latest update. I already cleared my cache in my plugins. I have reset the server many times.
Does anyone have any advice???
Server Version: 1.15.3.858
Player Version: 2.31.0.967-a95b6d76
Client OS: Windows 10 1809 - Zotac Mini PC
Server OS: Windows Server 2012 R2 Standard - HP ProLiant ML350 G6 - Dual Xeon E5540
Sony 7.1 AV Receiver
I have a similar problem, but only and specifically with Movie Extras. Everything else is fine.
Are you having this problem with all media types, or just some?
Cheers… Andy
It doesn’t seem to be downloading metadata for movies all together.
Hmmm.
So this has only recently started happening since an update?
I assume that its ok for TV episodes and music?
I also assume that you have been using Plex for a while now and your file and folder naming is correct?
Beyond incorrect file names, the only things I can think to check would be which scanner and agent you are using for this library - I use Plex Movie Scanner and Plex Movie Agent.
Also have a look in Settings, Agents, and make sure that there is nothing unusual set or unticked in there.
Lastly, try to create a test Movie Library, pointing it to a different location on your Server, and add a few movies to see if that works.
Cheers… Andy.
