I just recently started using Plex and every time that I try to add some media, nothing is added. instead it just tells me that the library is empty. how do I get data onto plex and it actually accept it?
Anne
Anne
How are you trying to add it? What type of media are you trying to add.
https://support.plex.tv/articles/200288926-creating-libraries/#toc-1
https://support.plex.tv/articles/#cat-your-media
Basically you should have separate main folders for each type of media, Movies, TV, Photos, Home/Other Videos and Music.
Say if you have a folder called Movies and in that you have a folder for each individual movie file. D:/Movies/Batman (1989)/Batman 1989.mkv When you create your library, select that it will be a Movie library. then when you pick which folder to add, only pick the folder D:/Movies
