Hi. I’m using Plex Server on a Pi 3 and for some reason, it refuses to scan and add files to Plex from 1 specific folder. I’ve checked the permissions and those are set properly (same as all other directories). I’ve even renamed the directory, moved it around, and nothing seems to work.
Is there a log I can check that may give me some information on why it won’t add files in this particular folder to Plex? Thanks!
