Plexamp 4.3.0 blank screen
Plexamp 4.3.0 nothing but a gray rectangle here (on Gentoo). 4.2.0 works fine. How do I disable auto-update so 4.2.0 stops removing itself every time I run it?
(Never mind - chattr +i works)
I have a similar issue on Windows. But I don’t think Plexamp is removing itself, so the chattr +i trick didn’t work for me (make binary RO with GUI).
Here is a screenshot of Plexamp (with the parent powershell running in the background for “logs”):
The tree of plexamp processes is as follows:
  • “C:\Users\Axel\AppData\Local\Programs\Plexamp\Plexamp.exe”
    • “C:\Users\Axel\AppData\Local\Programs\Plexamp\Plexamp.exe” --type=renderer --user-data-dir=“C:\Users\Axel\AppData\Roaming\Plexamp” --app-user-model-id=tv.plex.plexamp --app-path=“C:\Users\Axel\AppData\Local\Programs\Plexamp\resources\app.asar” --no-sandbox --no-zygote --lang=en-US --device-scale-factor=1 --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=4 --launch-time-ticks=74770056511 --mojo-platform-channel-handle=1664 --field-trial-handle=1136,i,10075344954416573108,4361770308487222022,131072 --disable-features=SpareRendererForSitePerProcess,WinRetrieveSuggestionsOnlyOnDemand /prefetch:1
      • “C:\Users\Axel\AppData\Local\Programs\Plexamp\Plexamp.exe” --type=utility --utility-sub-type=network.mojom.NetworkService --lang=en-US --service-sandbox-type=none --user-data-dir=“C:\Users\Axel\AppData\Roaming\Plexamp” --mojo-platform-channel-handle=1432 --field-trial-handle=1136,i,10075344954416573108,4361770308487222022,131072 --disable-features=SpareRendererForSitePerProcess,WinRetrieveSuggestionsOnlyOnDemand /prefetch:8
        • “C:\Users\Axel\AppData\Local\Programs\Plexamp\Plexamp.exe” --type=gpu-process --user-data-dir=“C:\Users\Axel\AppData\Roaming\Plexamp” --gpu-preferences=UAAAAAAAAADgAAAYAAAAAAAAAAAAAAAAAABgAAAAAAAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEgAAAAAAAAASAAAAAAAAAAYAAAAAgAAABAAAAAAAAAAGAAAAAAAAAAQAAAAAAAAAAAAAAAOAAAAEAAAAAAAAAABAAAADgAAAAgAAAAAAAAACAAAAAAAAAA= --mojo-platform-channel-handle=1168 --field-trial-handle=1136,i,10075344954416573108,4361770308487222022,131072 --disable-features=SpareRendererForSitePerProcess,WinRetrieveSuggestionsOnlyOnDemand /prefetch:2
The “logs” I find in powershell are:
Main: Display bounds x:0 y:0 w:2560 h:1440
Started Media Service: false
Checking for update
Update for version 4.4.0 is not available (latest version: 4.4.0, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
[22088:0930/172331.910:ERROR:gpu_init.cc(481)] Passthrough is not supported, GL is disabled, ANGLE is
The last line there appears only after a while of waiting, rest comes instantly. No logfiles seem to be open when I inspect the processes’ handles.
I’ve uninstalled and reinstalled plexamp, purged it’s data, and no dice. And the app worked yesterday (and has for many weeks), any ideas?
Same issue here on Windows 7 (I know, I’m old school). I have ran revo uninstaller multiple times and tried a fresh install - no dice :frowning:
Yeah, could mention that I’m also running on Windows 7 :slight_smile:
No dice? I’d really need help with this…
Updated to v4.5.1 and the problem fixed itself. v4.5.0 might have been the real fix as Electron was updated in that release.
I am having this same issue after the 4.5.2 to 4.5.3 update.
Deleting all the contents of \AppData\Roaming\Plexamp resolved this issue.
