Server Version#:1.43.3.10896
Player Version#:V4.50.13 Beta 5
Hey Yall,
Has anyone else run into this with the new PlexAmp Mac app (beta)?
I’ve set up keyboard shortcuts, but they keep working even after I close the PlexAmp window (Still running in the background) and switch to another app like Firefox or Chrome. The shortcuts still control PlexAmp instead of the app that’s actually in focus.
It’s really annoying. For example, if I map Spacebar to play/pause music, I can’t use Spacebar anywhere else as long as PlexAmp is running. The only workaround is to disable that shortcut so I can type or use Spacebar normally. The same goes for other keyboard shortcuts.
Is this a known issue?
Also I see there is no way to manually set the sample rate of the music. Is this dynamic now? Does it change as songs with different sample rates come on?
Cheers,
