I love the new Plexamp app and I use it on my iPhone, but a bug makes it currently almost unusable for me. I listen to audiobooks and when I end playing, close the app, and return later, the progress jumps back to where it was days ago, not the most recent position. I tested this several times and was able to reproduce it over and over again.
This should work (although isn’t an officially supported thing) if you enable the library setting “Store track progress”.
Hi Elan, thanks so much for your reply, I really appreciate you responding personally. I’ve got “store track progress” activated and it’s been working well on the Plex app on my iPhone, but Plexamp seems to have an issue with it. I’m happy to record a little screen capture video to document it, if it helps.
