Plexamp - on MacOS - Clicking the Waveform skips the Track
Server Version#: 4.145.1
Plexamp Version#: 4.12.2
MacOS 15.4.1
When I click on Plexamp’s waveform, approx 1/4 of the time, rather than jumping around the track as expected, it skips to the next track instead.
A quick observation / hunch is that it seems to be happening on flac files, not mp3s.
Not specific files.
I just rattled back and forth through some flacs clicking, and here’s the log.
Edit - removed to tidy.
I have a couple of screen recordings, if that helps too. Can’t upload them direct, unsure where best to host them.
Thank you!
I’ve looked through your logs, but it’s hard me to see where you had the issue, as it appears you were mashing around on seek and next/prev like a coked out baboon (and I say that with a sense of endearment).
I can’t trivially reproduce the issue, is there any chance of logs where you a) reproduce the issue and then RIGHT AFTER that, post Plexamp logs? (Like once it skips inappropriately and is starting to play the next track).
Alternatively, and even better, reproduce it with only a single item in the play queue, so that when seeking around like crazy it ends playback instead of seeking, that would be an even cleaner log.
Actually, belay that request, I think I see the issue.
Thanks for looking into this and getting back to me.
You’re quite right, I was banging around between tracks. My hope was that it would give more evidence… But, yeah, I get that it actually causes more wood for the trees (to swing from?).
In which case, thanks for persevering. Please do give me a shout if you need a cleaner log to investigate, but your last sounds promising, so I’ll stay tuned.
Thanks again.
Should be fixed in the next release!
Thank you kind sir! I’ll keep an eye out.
