PlexAmp playback crashing Plex server
That was extremely beneficial and a nice, thorough overview for me. You are much more experienced in all this that’s for sure, but I am learning and trying hard to share my experiences.
Correct, Syno is not crashing, nor the server environment. Only Plex stops for inexplicable reason(s).
I can try that but like many music lovers, my mood can change during my walk so downloading playlist(s) may not match that mood but it is a good thing to have as a standby. And I certainly have room on my 512GB iphone for my music. I can do that certainly. In fact, there are times when I bring my iPod Classic 7th gen (final model) and it is a good safety net.
This is a really interesting suggestion that I’d not considered as it relates to this. Here is what I had set. Can you please suggest where I should have them?
Wi-Fi caching - 15 tracks
Cellular Caching - 5 tracks (is what I had, I’ve now changed that to 25 - is that proper?)
Cache size - 512mb - should I increase to 1, 2, 4, 8 GB or more? Would this help?
Network Speed - Unlimited
Exactly.
Ditto.
Could you explain this a bit more? The Access Point you switched to and so forth is what I’m trying to understand on your end and then as it could relate to mine (and things I could do to improve).
I agree it doesn’t happen with the same song file. Interesting that it seems to be iPhone users specifically. That’s a bummer but I’m sure this will get figured out.
I’ve not done this with Plex before so with the massive amount of work I’ve done as things have progressed from my first Syno (720+) to the second (423+) and now my 1621+, I am very, very cautious. Is there a way to back up everything just in case? I do have things backed up in many forms but just want to make sure.
Thank you again for your excellent feedback! I’m looking forward to hearing back more.
I’m sorry that happened but also glad so that it’s something the community and Plex devs can get pinpointed - though Atomatth has already suggested the beta release related to the transcoding fix might be the solution. What is your opinion on that (not trying to challenge anyone here, just for general observation)?
What were you listening to at the time (iPhone? Android?)…
Thanks!
There are lots of folks here way beyond me in experience. You’re doin’ excellent. :slight_smile:
We all start somewhere and all have different experience levels for these things so no worries. It’s easy to cross communicate in these areas so nobody worthwhile is judging anybody for it.
Some days I just want my Sony MD player back!!! I’ve got a Touch, Nano and a clip Shuffle around here somewhere too. I use the Touch for handing music control off to others in the car or at home without having to hand my actual phone over. :slight_smile:
The “download” option is a lot more limited than the full app but I use it for times I can’t connect back to the server (like on an airplane). Smart playlists will auto-update so I have a few of those I have setup as downloads so I always have something to play for a few hours.
For Settings→Playback→Caching here are my settings:
Wifi\Cellular cache ahead: 40 tracks
Cache size: 1GB (Plex will hold onto tracks it’s already played, this is probably overkill for me)
For Settings→Downloads here are my settings:
Quality - Max
Everything else enabled so smart playlists auto-update and such and “prefer downloads” at Always.
You manage how much space it takes up just per playlist… I think. That’s how I do it anyways. Someone else can chime in with more specifics maybe if that’s a question (or search for another topic on PlexAmp download functions maybe).
This last time the Plex server locked up I didn’t notice until I was done with chores because my caching kept playing the queued tracks. I won’t notice the “crash” unless I do something in the PlexAmp that requires checking back in to the server. Having 40 tracks ahead cached is about 2-3hrs of music. :slight_smile:
Sure!
I have 3 wireless access points in my home - meaning 3 different wifi connection points that devices can use. This helps make sure I have good wifi coverage around my house (which has old construction with wifi killing materials in the walls), backyard and a detached garage. As I move around the house or go to the garage and around the outside of the house my device will switch to the AP that provides the best connection. This hoping could replicate a similar situation as “going remote” if the bug is related to communication\network route changes. I could see a bad communication loop in the server eventually locking it up (odd but possible).
Well…. I’m on the beta now and had the bug today so that wasn’t the fix. It was still a good idea to try it out and see if it helped and having more information, even if it’s a failure, can help with troubleshooting.
So if you were inclined to try it to get a fix… it doesn’t seem to be a fix so there’s probably less inclination for you to upgrade to the beta.
If you want to though…
Totally fair to be safe! Backups are king!
Here’s the generic “backup your server” article: https://support.plex.tv/articles/201539237-backing-up-plex-media-server-data/
So for Syno the easiest way is to just copy the entire Plex Media Server directory if you have the space but you can skip the caches folder to save some space. This FAQ from ChuckPa gives you file locations (and lots of other good Syno info in that FAQ topic - not sure why it isn’t pinned under the Synology specific forum but it’s in the “tips, tricks” forum area): Synology FAQ - Questions, Answers, and How-To's - #18 by ChuckPa
I think you should have a “Plex” share though and that’s where it’ll be (I used to run Plex on Syno but it’s been a bit now and can’t remember - QNAP you gotta do a trick).
It might be good to setup a regularly scheduled backup for it. You should be able to setup a Hyberbackup task on your Synology if you wanna automate it (I backup mine every week so I don’t lose too much watch history).
You don’t have to backup your media for this process just that directory.
If you have to do a restore you essentially just copy back that directory. I have never had to do that even with several upgrade\downgrades under my belt on Synology and QNAP but it’s always good to be safe.
So far the current beta has been pretty stable and out for a few weeks now without any obvious gotchas.
If you wanna do a bit more you can use ChuckPa’s DBRepair tool to help with Plex Media Server maintenance as well. Includes backup\restore option but it’s more of an SSH\Terminal app and some folks aren’t comfortable with that but this is pretty well detailed tool.
GitHub: GitHub - ChuckPa/DBRepair: Database repair utility for Plex Media Server databases
Plex topic: DBRepair development - if you have trouble with it try there. :slight_smile:
At this point, it’s clearly a recurring problem so should be replicable but pinning the right scenario down might be hard to do for such a small user base impact. Hopefully a dev will get some inspiration and can draw out the missing info based on their more intimate knowledge of what’s happening in the apps.
So as Plex Media Server and PlexAmp update we’ll just keep trying things and uploading logs and hopefully it’ll get narrowed down.
@Atomatth … so umm… 2nd crash today… so more logs.
I was listening to music while typing up these posts and it happened. Wasn’t moving around and definitely not remote but it’s possible an AP hop happened in there even though I was stationary (I don’t have that being logged on my network so can’t confirm but it’s not uncommon in the location I was at in my home for a device to switch AP).
4:50PM central time is when I noticed the crash.
PlexAmp logs #2:
Plexamp-Logs-2025-12-15-2.zip (646.9 KB)
Plex manually grabbed server logs #2:
Plex Logs 2025_12_15-2.zip (3.0 MB)
Edit: Logs from Plex after restarting Plex…
Plex Media Server Logs_2025-12-15_16-57-45.zip (2.1 MB)
I changed mine to reflect your settings.
I changed these as well to what you have.
I also have various access points, including a strong one on my lanai (I think it’s a Luxul one, but have to check, but it cost about $700 as I recall). Connection in my house is never (or rarely) an issue.
And I agree, I don’t think I’d upgrade to beta just yet.
Thank you for this. I do back that up to my Hyper backup as well as two different attached USB’s. So I will backup from my 1621+ to my 720+ for lots of stuff, everything I would need. All content such as movies are backed up to my computer as well as external drive(s). Save, and save again is my motto.
I have used that and it’s part of my arsenal so to speak.
That should cover me as my walks (or workouts) are usually around 60-90 minutes.
THANKS SO MUCH! Wish us luck (no more crashes!)
@Insomnic_1 @bubbascant excellent EXCELLENT!! amount of details here!! I really appreciate it. :plexheart: :plexheart:
Thank you very much. Imsomnic_1’s input has been really valuable for me as well. I’m excited to see this figured out, as I’m sure it will be.
Thanks for your reply!
I dunno if this will be helpful but here are logs from a working session.
Went out for about 20 minutes - started on wifi, went remote, came back to wifi - without a crash.
Started at little after 1PM CT and ended just a minute or two before grabbing the logs.
Plexamp-Logs-2025-12-16-1.zip (685.8 KB)
Plex Media Server Logs_2025-12-16_15-33-32.zip (2.9 MB)
Since being remote seems to be a factor I thought providing a “worked fine this time” set of logs from my setup for comparison might help.
My current theory that I’m going to try to target is that something is happening after the currently cached items are played through and a new set of tracks are being fetched. There is also something to do with the phototranscoder (album art) when these new tracks are fetched.
That makes sense. Thanks for keeping on it for us!
Would that tie into being away from WiFi? That’s the only time I have problems as you know. Seems to make sense (what you’re saying).
Thanks for keeping us posted.
The thought occurred to me to mention related to your last post - is that what would cause Plex to go into “Manually stopped” on my Synology NAS (which is why it stops playing as you know)? If it happens, it is always triggered by me skipping a song(s) or bringing up a new playlist - always when away from WiFI.
Smarter minds than me will surely figure this out. I thank you again so much for staying on top of this for us. :slight_smile:
Atomatth, can I delete the logs I posted here of my crash (i.e., did you download and get whatever info you need from them)? Since some usernames include identifying names, I don’t want to keep them up forever. :slight_smile:
Yes. I got them. Thank you.
Any progress on this? I’m getting tired of all the crashes lately. I can provide another log of a crash if that helps.
Holiday time usually means very little activity.
Also they are working on a lot of new stuff on the server - new transcoder and “new experience” - which also seems to have slowed down releases and fixes so bit of double whammy right now.
I’d look for releases to start coming through shortly after the new year. :slight_smile:
I’d say keep throwing logs up until they say stop. It also keeps the bug on their radar and pull the topic to the front where others might see it and join in if they are having the same issue.
I did have a several hour remote use that didn’t fail\lock-up the server the other day. That means the problem isn’t easily replicated - one day it crashed twice for me and another day it didn’t crash at all.
We also don’t have a lot of folks checking in on this bug topic thread so it’s not impacting everyone. Looks specific to iOS folks at the moment (multiple server environments but all using iOS PlexAmp clients it seems).
That makes troubleshooting this bug - that isn’t widespread, replicated, or consistent - tricky. I think Atomatth has a good working theory that it’s between cache and fetching and my additional theory is specifically a communication hiccup in that fetch, specific to iOS, as a culprit creating a loop that the server can’t complete that locks it up.
For example, iOS client says “gimme X via path 1” and server says “Sure! Here’s X via path 1” but client has switched to a path 2 in the meantime and the server tries endlessly until resource lock freezes things up or security mismatch says “Just die instead of being hacked” (which VPN disconnects used to do to MS apps). So many factors there… just thinking out loud. :slight_smile:
Here are my logs from my crash at about 6:40am on 12/30/25. Atomatth, let me know if you have them and I will delete after (identifying info, etc).
Meanwhile, has anyone found a better workaround for this? Perhaps playing via the web interface in mobile Safari? Not sure if it would be possible to skip tracks with a headset with that.
More logs if you need them Atomatth. It’s crashing at least once a week. But what’s problematic is the PMS exe can’t be terminated with task manager. Even with TM opened with admin privileges, it gives an “access denied” message. Windows is even unable to shut down, requiring an improper power-off shutdown.
I have an update. Last night, I went to my PMS app on my Apple TV as I do most every night and it said the server wasn’t available. That is a very rare instance and certainly hasn’t happened in recent memory. Before I restarted Plex on my NAS - while on my AppleTV - I went to my other NAS (DS720+) (which points to all the content which is stored on my 1621) and the content played fine. So the DS1621+ is working fine.
But to get things to play from my 1621+, I had to go on my 1621+ Synology NAS to restart Plex. Before I restarted, no surprise that Plex had been stopped (Manually stopped). I did not do that. I restarted Plex and it came back.
Then this morning on my walk, my PlexAmp crashed about 10-15 minutes into my walk. On my iPhone, I had to log into my Synology using Quick Connect. Once I was, as many times before, Plex had been stopped (as this forum exchange has covered extensively). I restarted it but PlexAmp wouldn’t come back. I then went back to Synology and Plex had stopped again. I tried it several more times but PlexAmp wouldn’t come up so I couldn’t play anything. I waited about 10 minutes and then restarted Plex on my NAS with Quick Connect once again. This time I was able to get PlexAmp playing music once more and it continued for the duration of my walk.
So this was when away from WiFi. It never fails when I’m on WiFi at my house.
I am uploading logs from my Plex as well as the PlexAmp.
Plex Media Server Logs_2026-01-07_13-35-43.zip (2.6 MB)
Plexamp-Logs-2026-01-07-1.zip (2.1 MB)
@bubbascant can you download a copy of your DB and share it with me? It maybe too large to share directly within the forums so you may need to use an external file share service like Google Drive or something similar. Feel free to DM me.
