I noticed that the default setting for the PlexAmp system tray icon is set to “Only Show Notifications”. Thus, after launching the software, the icon quickly vanishes, making it perplexing to change libraries / servers unless you manage to think of looking for PlexAmp in your ‘Customize’ system tray settings.
If you’re meant to use the system tray notification to control these aspects, don’t you think you would set this to ‘Show Icon and Notifications’? As you can’t control any of the libraries via clicking on the Taskbar icon, let alone within the software, I find this to be pretty nonsensical. (I could be missing where you can change it in the application. But since none of it is blatantly evident, I don’t figure you can.)
I noted these observations on W7 x64.
