I’m running Plexamp on Gnome. There is no system tray icon visible, am i missing something here?
According to this website, there is a tray icon available on Ubuntu after setting the environment variable XDG_CURRENT_DESKTOP=Unity. On my system this variable is set to ‘GNOME’ and even if i change it there is no tray icon.
I’m using the latest Arch Linux and Gnome 3.36.3. Plexamp is installed via plexamp-appimg from AUR and is started with ‘–disable-seccomp-filter-sandbox’ because thats the current workaround for arch, otherwise plexamp doesn’t display anything. The gnome extensions appindicator-support and tray-icons are installed and enabled, so there should be a tray icon in the upper right corner (other apps show tray icons).
Thanks!
