Plexamp (v3.1.1) Not Playing Downloaded Songs on Phone When Offline
Went camping the other day with my phone and brand new JBL Charge 4 speaker. Out in the boonies with no internet I could not get my phone (Pixel 3XL) to pay my downloaded songs, just got a constant spinning circle. :frowning: Good thing I had MediaMonkey installed. :slight_smile:
Now at home I put my phone in airplane mode and when I start Plexamp I the message “WHOOPS We had an issue getting data from FreeNAS Server, and we’re pretty bummed about it.” … we so am I!
Has anyone had similar issues getting downloaded songs to play when no cell or WiFi service is available. I’d figure this is the whole reason to DL songs. :-/
I have noticed that here at home, in airplane mode, at the bottom of the screen with the WHOOPS message is a box with a song with the the play triangle. If I click that my phone will start playing my downloaded music. Unfortunately this option wasn’t available on my camping trip. Still I shouldn’t get the WHOOPS message when offline.
I know that Plex does not link your regular library and the downloaded files – so if you click on a song you know you have downloaded on the home screen, you’ll get a spinning wheel and an error message.
I’ve run into that situation a number of times.
You can only actually start downloaded items from the Downloads tab.
Just double-checking if that might have been the case for you as well?!
Best I remember I just clicked on the Plexamp icon on my phone and got nothing but a spinning circle. I’ve sure if I had other options I would have been hitting every option.
i’m confused. did you see tabs at the bottom of your screen? where you in the player with the “v” option to close?
when you’re offline, downloads are available on the downloads tab.
Sorry guys I didn’t get more data. If it happens again I’ll make some notes and/or get some screen shots. If there were tabs at the bottom of the screen I’m sure I would have been tapping them. There was no “v” to close.
then i’m not sure what screen you were on :sweat_smile: please let us know if you can reproduce.
