So if I go into the add on and navigate to a library and then on deck, I get a list of shows. If a show was stopped in the middle, when I select it, it pops up a menu on the left and asks if I want to start in the middle or at the beginning. I use the Titan skin and I create a widget that points to the same on deck point in the home screen. It lists the show and tells me I’m 10% into the show. When I select the show, it starts from the beginning and doesn’t let me start in the middle. Any idea why?
More info.
If I use the Plex app for android, in the Discovery tab there is a selection for On Deck and another for Continue Watching. When I go to the PleXBMC add on, I get the On Deck option, but there is no Continue Watching option. Is this an over sight? Did Plex add this category and PleXBMC needs an update to include it? Maybe I have some server setting wrong?
