You are running PMS on 192.168.1.19. Are you also running plexconnect on the same machine? If so then refer to your setting.cfg, ip_pms= do not match, also ip_plexconnect= do not match either. Believe both should be set to 192.168.1.19.
If you can dedicate an ip address to the machine running the server+plexconnect this can simplify things in that you can then punch in that address in settings.cfg. If dedicated, turn enable_plexgdm = FALSE and enable_plexconnect_autodetect = FALSE. This eliminates the searching for the PMS and Plexconnect.
Because enable_plexconnect_autodetect = True & enable_plexgdm = True then neither ip_pms or ip_plexconnect are used, the values here are just the defaults.
But because artwork is not being displayed, it is worth trying to set ip_pms = 192.168.1.19 and _plexgdm = FALSE so that If the machine has multiple IP's (Via VPN, mutiple NIC's etc) then Plexconnect alreasy talks to PMS on the same IP address
Thank you for your suggestion. I gave it a shot, but unfortunately the issues persist.
Well there is something wrong with your network setup in the PMor somewhere arms your pMS is replying with ip 192.168.56.1 a very different subnet to the 192.168.1.33 your ATV is on.
When you made the settings.cfg changes above did you restart Plexconnect?
I can't imagine what would've changed, why, or how to go about fixing it. I did restart PlexConnect, and have tried restarting my PC as well. Very odd.
You could always downgrade to iOS 5.3 jailbreak and install PlexConnect directly upon your aTV2 Post 355. This would make your aTV2 portable as well (e.g. vacations). Only downfall is custom Pil / Pillow themes are not possible with the jailbroken iOS 5.3 only iOS 6.x+.
Are you running a VPN or similar?
I do subscribe to a VPN service, which my router is configured to connect to. I've been using that setup prior to this problem with PlexConnect, however.
I was able to get mine working by adding my local subnet and mask (10.0.1.0/24) to “List of IP addresses and networks that are allowed without auth” and restarting PlexConnect. I also hardcoded my ip_pms, but I’m not sure that helped.
