PlexConnect plays music not vids!
Ok... did have a closer look.
From your log...
PlayVideo requests this...
as port 32400 was found during PlexGDM.
However your server - according to MyPlex - uses a different port (discover):
       ... port="23963"
Which one is correct? To me, it looks like PlexGDM is faulty.
Also, your two servers have completelly different global IPs... are the both connected to the internet? Do they share the same home-net? This kind of confuses me...
Short term solutions...
option 1) disable PlexGDM and specify your local server manually.
option 2) disable PlexGDM and manually select a non-existing server, thus only relying on MyPlex.
option 3) fix your Waterfront PMS to show the correct port...
option 4) log out of MyPlex... though, I guess, your server's port would still show up wrong.
Hm. Thinking about it... I guess PlexGDM shows the "local port", whereas MyPlex looks more from the outside? Did you set up a port forwarding with number change?
Sorry for the delay in repling. After having some other issue with pled on my server, I purged the whole thing and reinstalled it.  Once it was up and running again, low and behold PlexConnect worked without any problems!  So looks like it was a server issue.
Thanks for your help in trying to track down.
