Server Version#: 1.22.1.4228
Player Version#: 4.54.4 (web)
Hello,
I am running the plex plugin on FreeNAS version 11.3-U2.1. This started happening a little bit ago but I figured an update would fix it. When I attempt to stream a TV show it buffers infinitely. I checked the logs on the server and in the javascript console and they both show 404s for a /transcode directory. I have an except of the logs below and attached the whole log bundle as well. Movies seem to work fine but I noticed some of the pre-rolls that I have don’t load while others do. All this media has worked in the past. This is happening locally and remote-ly.
I tried deleting the codecs that I saw in the post below to no avail.
I’ve blown the plugin away and re-downloaded it and set it up with no luck. There was a permissions issue with /transcode previously but I resolved that and the subdirectories have been created by plex successfully.
I’ve also seen some Transcode runner appears to have died errors in the console and the other post linked below doesn’t seem to have the same cause.
Some Error issuing curl_easy_perform(handle): 28 errors have also been showing themselves but I have IPv6 disabled and the server is still accessible outside the network.
