PMS 1.8 / Android Beta Time Shifting
What version number?
Check the mobile beta board:
https://forums.plex.tv/categories/android-mobile-beta
@kegobeer-plex said:
New beta release for mobile. Guess what’s working now?
Doesn’t work this end, and I’m running the latest beta
I’m able to bring up the TV guide but not actually steam anything. Who’s the mod for this sub? Can they move it over to the Android mobile sub?
And now it’s there!
Took a while to come up had to restart pms
Working lovely! @sixones excellent work!
Show the Guide. I have a hard time believing that you’re the only one that has live TV. I pulled 2 updates to the plex mobile client today. Neither enabled live TV at the client end for Android Mobile. Not without tricking it to run as an Android TV device anyway.
Update: Well I got mine working by connecting to my home Wifi first. Then it populated on the pop out nav at the top. Even now that I’ve disconnected from my wifi, I still have access to the live streams.
@arcanexvi it’s there, for whatever reason it doesn’t show up some times. #beta
Mine has disappeared again after being off WiFi for a bit. Turned wifi back on and it eventually populated again. Killed wifi now and seeing if it will stick around.
I wouldn’t lie about it.
@kegobeer-plex it seems to be real intermittent, i had it fine this morning, then left home went to test it whilst i was out and about, and no option, got home back onto wifi and the option is gone again.
Again, more experimenting and it looks like my ATV device (Nvidia Shield) is exhibiting the same behavior which leads me to believe that there’s something in the build that’s causing the issue, not directly related to mobile. Live TV discovery is just taking a while.
Well, that update didn’t take long :wink:
