Hi, I am trying to get a USB tuner, Mygica D689 DMB-TH to work with PMS on a Raspberry Pi 3 with no luck, PMS webUI does not show the tuner.
$ lsusb
Bus 001 Device 004: ID 0572:d811 Conexant Systems (Rockwell), Inc.
$ dmesg | grep dvb
[ 4.170088] dvb-usb: found a ‘Mygica D689 DMB-TH’ in warm state.
[ 4.542938] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 4.847887] dvb-usb: schedule remote query interval to 100 msecs.
[ 4.847974] dvb-usb: Mygica D689 DMB-TH successfully initialized and connected.
[ 4.848129] usbcore: registered new interface driver dvb_usb_cxusb
$ uname -a
Linux rpi-plex-001 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
Plex version
Version 1.11.0.4666 (Beta channel)
Plex Tuner Service.log
INFO - * dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5, Name US
B Stick, Standards 1
Am sure the tuner works, added plex to video group, and run dvbtune as user plex:
$ sudo -H -u plex bash -c ‘dvbtune -f 626000’
Using DVB card “AltoBeam ATBM8830/8831 DMB-TH”
tuning DVB-T (in United Kingdom) to 626000000 Hz
polling…
Getting frontend event
FE_STATUS:
polling…
FE_STATUS: FE_HAS_SIGNAL FE_HAS_LOCK FE_HAS_CARRIER FE_HAS_VITERBI FE_HAS_SYNC
Event: Frequency: 636600000
SymbolRate: 0
FEC_inner: 9
Bit error rate: 0
Signal strength: 54976
SNR: 0
Any suggestion? Thanks in advance.
