Server Version#: 1.26.1
Plex no longer open on my iMac, running 10.15.7. When I click on the Plex icon in Applications it expands out but nothing happens. Have tried deleting app and reloading (twice). Anything else ~I can do?
Check console to see if it’s crashing.
A common overlooked cause, no more HD space - drives are full.
Try the “plex dance” (search in forums for the mac instructions).
Good luck.
When PMS launches, the main app hides.
When it’s running, there should be a Plex icon in the top-right of the menu bar.
If there’s no icon it probably isn’t running.
Can you access it at http://127.0.0.1:32400/web ?
There’s no icon - I’ve been using Plex for a few years and it’s always worked until now. I can’t access that link I’m afraid.
I found this in console:
May 20 08:24:18 Nicholass-Mac-mini com.apple.xpc.launchd[1] (com.plexapp.plexmediaserver.2324[74252]): Service exited with abnormal code: 255
There’s plenty of room in the drives.
