Server Version#: 1.19.5.3112
Player Version#: 4.38.2 (Plex web)
I recently lost more than 90% of my TV library, when the drive it was stored on died. I’ve since replaced the drive, but have not re-added any of the missing items, because I didn’t have backups.
It’s been more than 2 weeks, and all of the missing items are still in my library. Nothing I’ve tried removes the old content. Things I’ve tried:
Manual library scan
Manual emptying of trash
Refresh metadata
temporarily add media to source folder for scan
Delete source folder
None of the above has made any difference, and the missing items don’t show the trashcan icon… They just fail to play.
The biggest problem you have is Pop isn’t handing SNI (Server Name Identification( correctly.
Jul 23, 2020 12:26:25.878 [0x7f0406104700] DEBUG - Completed: [127.0.0.1:43942] 200 GET / (6 live) 1ms 5059 bytes (pipelined: 1)
Jul 23, 2020 12:26:32.804 [0x7f0406104700] DEBUG - EventSource: Resolving port 443
Jul 23, 2020 12:26:32.804 [0x7f0406104700] DEBUG - EventSource: Failure in SNI configuration (0 - Success).
Jul 23, 2020 12:26:32.804 [0x7f0406104700] ERROR - EventSource: Retrying in 600 seconds.
Jul 23, 2020 12:27:03.183 [0x7f0407187700] DEBUG - Request: [127.0.0.1:43946 (Loopback)] GET / (6 live) Signed-in Token (jasoncollege24)
Jul 23, 2020 12:27:03.184 [0x7f0405903700] DEBUG - Completed: [127.0.0.1:43946] 200 GET / (6 live) 1ms 5059 bytes (pipelined: 1)
As direct result SSL isn’t working right and remains in perpectual retry every 10 minutes (600 seconds).
You need to resolve what’s going on there.
Also be advised, Pop isn’t supported. While it may be a derivative of Ubuntu/Debian, there’s a reason it is. Whatever they removed might well be the problem with your TLS SSL.
Sounds like you’re telling me I need to change the OS on that PC… story of my life. the OS is on it’s own drive, and is separate from my home directory, and all libraries.
Can I just delete the OS partition, install kubuntu, (which I know is supported), and keep going, or do I need to start completely fresh?
