PMS storage location missing
Server Version#: 1.20.2.3402
Player Version#:8.7.1.20931
Hello,
I am running PMS on a shield pro (16GB internal storage) and I am trying to modify the storage location to a shared folder on a Synology NAS.
Unfortunately, when I go the PMS storage location settings, I have only two options :
  1. internal (system storage location)
  2. internal (user accessible storage location)
Following the procedure found here : https://support.plex.tv/articles/moving-server-data-storage-location-on-nvidia-shield/
there should be a third choice : Media but it is missing.
I am currently running the 8.2.0(32.6.435.1) version of the shield OS.
That procedure is for moving the Plex data folder, where Plex keeps its internal database, metadata about movies & tv shows, etc.
The third choice is for an external drive such as USB drive or SD card.
You cannot choose a network drive such as a NAS.
You can choose a NAS to store your movies, tv shows, and other media.
See Plex DocsNvidia ShieldMedia Storage Options for NVIDIA SHIELD.
Also review Limitations When Running Plex Media Server on NVIDIA SHIELD.
Thanks for your quick reply!
Indeed I mixed up two different things.
I’ve then disable Video Preview Thumbnails as recommended and this should do the trick.
