I just dumped over 700 episodes of One Piece on my Linux PMS setup, however about 100 episodes were categorized as a duplicate with another season, like this:
No. From what you’ve shown me, although I would need the full XML of the episode to be 100% certain, your files are dual audio meaning PMS will pick up that information as well as any embedded subtitle streams just as it did before.
If you use external subtitles, renaming the video files will break the subtitles.
Luckily though, Filebot will take care of the external subtitles as well, if you use the right renaming instructions:
Just tried FileBot and it worked rather well. Unfortunately FileBot only downloads from OpenSubtitles.org which doesn’t have the subs in my language so I ended up grabbing a version with embedded subs. However that version is named with Japanese characters (One Piece’s original names). Is Plex compatible with that?
