Server Version#: 1.21.3.4014
Player Version#: 1.29.0.1885-67668ec3
I get cropped poster images when adding a movie that is NOT matched. If I match the movie and add the exact same poser, it looks just fine.
I have included a screenshot of what it looks like, and included an exact copy of the image that gets cropped. Although, I have seen this happen several times, so I doubt it really depends on the poser its self. It also seems fine on my Apple TV, so guessing it is not a server issue.
Same here. I have a concert that I downloaded from Youtube and I couldnât get the cover to work since this event doesnât exist on any metadata website.
If you are using the older Plex Movie (legacy) or TMDB agents when you unmatch something it starts to use personal movie agent which treats the item like it was in an âother videosâ library. which are meant for home movies with no posters and horizontal.
I think this is an app issue as well since it does not happen in all (it does happen on recommended screen of Android as well.)
Iâm making a bug report though I am wondering if there is anything holding you back from Upgrading Matching to use the new Plex Movie agent.
I also think itâs a bug because by default you canât set a cover properly, but if you follow the steps above you can trick Plex to do the right thing.
Itâs one of those lives singers have been doing on Youtube. I downloaded it and add to my concert library (movie type).
Plex cant find metadata for it because it doesnât exist. So I added a personalized poster that was being cropped like that:
But then, following the steps I posted here I was able to get the same poster the be shown properly
I really do hope thatâs NOT the work-around thatâs in our future - when we have the occasional âNo Match Possibleâ item and come against Plexâs Forced Landscape Artwork NightmareâŠ
If it is - thanks for finding it.
Seems like a PITA to me, but⊠wuduyagonnado?
To be clear I am not suggesting it isnât a bug. This is just the first time I have come across it with the new agent so wanted to be sure since i canât reproduce yet.
I also wanted to ask if you are using the local (IP:32400/web) or hosted (app.plex.tv) Do both have the same issue?
