Server Version#: 1.25.9.5721
Player Version#: 4.76.1
Posters for albums give 404 errors in the web console. Posters for TV and Movies do not. How can I fix this or is this a bug? Do you need additional logs or information?
The TV/Movies work.
This makes me think the posters are not downloaded properly which may have something to do with log entries like the following:
2022-04-05 18:34:32,829 (6274) : DEBUG (model:32) - Loading model with GUID plex://album/5d07c2b6403c640290900806
2022-04-05 18:34:32,829 (6274) : DEBUG (model:234) - Deserializing from D:\Plex\AppData\Plex Media Server\Metadata\Albums\9\dd9e2c0c95701a73cd2632b21486c30090af169.bundle\Contents\tv.plex.agents.music\Info.xml
2022-04-05 18:34:32,838 (6274) : DEBUG (runtime:88) - Sending packed state data (110 bytes)
2022-04-05 18:34:32,838 (6274) : DEBUG (runtime:924) - Response: [200] str, 600 bytes
2022-04-05 18:34:32,842 (5e94) : DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.localmedia/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKeHhzNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNQo4ODcxN3M0CmRiaWRpMApzNwp2ZXJzaW9uczM4CnBsZXg6Ly9hcnRpc3QvNWQwN2JjMWI0MDNjNjQwMjkwNGJjNzg3czEwCnBhcmVudEdVSURzNQo4ODY1NnM4CnBhcmVudElEczUKQWxidW1zMTAKbWVkaWFfdHlwZXMzNwpwbGV4Oi8vYWxidW0vNWQwN2MyYjY0MDNjNjQwMjkwOTAwODA2czQKZ3VpZHM0Cm51bGxzMgppZHIwCg__
2022-04-05 18:34:32,844 (5e94) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2022-04-05 18:34:32,844 (5e94) : DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.localmedia/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKeHhzNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNQo4ODcxN3M0CmRiaWRpMApzNwp2ZXJzaW9uczM4CnBsZXg6Ly9hcnRpc3QvNWQwN2JjMWI0MDNjNjQwMjkwNGJjNzg3czEwCnBhcmVudEdVSURzNQo4ODY1NnM4CnBhcmVudElEczUKQWxidW1zMTAKbWVkaWFfdHlwZXMzNwpwbGV4Oi8vYWxidW0vNWQwN2MyYjY0MDNjNjQwMjkwOTAwODA2czQKZ3VpZHM0Cm51bGxzMgppZHIwCg__
2022-04-05 18:34:32,844 (5e94) : DEBUG (model:32) - Loading model with GUID plex://album/5d07c2b6403c640290900806
2022-04-05 18:34:32,845 (5e94) : DEBUG (model:234) - Deserializing from D:\Plex\AppData\Plex Media Server\Metadata\Albums\9\dd9e2c0c95701a73cd2632b21486c30090af169.bundle\Contents\com.plexapp.agents.localmedia\Info.xml
2022-04-05 18:34:32,848 (5e94) : DEBUG (networking:143) - Requesting ‘http://127.0.0.1:32400/library/metadata/88717/tree’
2022-04-05 18:34:32,851 (5e94) : ERROR (networking:196) - Error opening URL ‘http://127.0.0.1:32400/library/metadata/88717/tree’
2022-04-05 18:34:32,851 (5e94) : CRITICAL (core:574) - Exception when constructing media object for dbid 88717 (most recent call last):
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-965587f64\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\agentkit.py”, line 1063, in _update
level_attribute_keys=cls._level_attribute_keys)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-965587f64\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\agentkit.py”, line 680, in TreeForDatabaseID
xml_str = cls._core.networking.http_request(‘http://%s:32400/library/metadata/%s/tree’ % (host, str(parent_id or dbid)), cacheTime=0, immediate=True)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-965587f64\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\networking.py”, line 346, in http_request
return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-965587f64\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\networking.py”, line 118, in init
self.load()
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-965587f64\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\networking.py”, line 158, in load
f = self._opener.open(req, timeout=self._timeout)
File “C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py”, line 435, in open
response = meth(req, response)
File “C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py”, line 473, in error
return self._call_chain(*args)
File “C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py”, line 407, in _call_chain
result = func(*args)
File “C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 403: Forbidden
