Cool, and also strongly recommend you enable 2FA
To confirm, I need to ask Graeme to open his plex account and delete my t user from his server?
Assuming this is the case it might be a problem, G no longer maintains his server
will do, didn’t realise you support 2FA, thx
No, you need to go to where you already was, and delete your account, if it has an X
As shown in the pic, my Plex My home in my account does not show a x for either G or N account.
Only when I highlight my T account it has an x for T (again T is the original account registered with my email)
The fact that there is no x available for G and N is the problem
And you need to delete that. The T account !
And don’t worry, since it’ll not actually delete your account, just remove it from his home
If I delete the T account I won’t be able to log back into Plex,
After I delete the T account what do I do after that?
deep breath, I did it
WTF!!! that worked,
T is now the only account listed,
What just happened?
I note that also deleted all my shared Manage Library Access config also
Most likely due to unclaiming your server
Thx, the answer is in the “How do I leave a Plex Home” process you sent me, sorry I didn’t read carefully enough
Thx for the help, this has been annoying me since 2019
