Greetings. I am hoping to get some assistance with some problems I have been having with the Commercial Removal feature of the DVR.
While performing some research, I cam across the following post that seemed to closely match my requirements. It was 2.5 years old, but I figured it was a good place to start.
Here is my current comskip.ini
I am running Plex Version 1.12.0.4829 on LibreELEC 8.2.2.
One of the most recent recordings I experienced issues with was the Friday, March 9 2018 broadcast of ‘Marvel’s Agents of SHIELD’.
The first 60 seconds of the show recorded fine (up to where Lash finds the drone). Then, the Commercial Removal feature removed from then (Shield Logo) until Daisy and Deke are looking through the supply closet (4-5 minutes later).
Through out the rest of the recording, the Commercial Removal process would mark the beginning of the commercial breaks pretty well (maybe a fraction of a second too early), but would then leave the ABC promos in place that would come towards the end of the commercial breaks. And there were also instances of where the first 4-5 seconds after the commercial break were cut.
This episode has a run time of just over 43 minutes (according to the ABC app), but my recording came in at 40:01. So with the removal of 4-5 minutes at the beginning of the show, and the non-removal of several commercials, I was still 3 minutes short.
Can anyone see what in my comskip.ini would be causing the problem?
Can anyone share a comskip.ini file that they have had great success with?
Does anyone know if there are any log files I can review to find out why the Commercial Removal feature made the decisions it made?
