Problems with direct external playback on the plex
Good afternoon,
First I want to apologize for my English.
I was using 5 simultaneous external accesses to my plex using the 480p configuration and it works normally with the 35 / 5mb internet.
Now I have switched my internet to a fiber and I have 200 / 100mb of internet.
with this, I want to have the external accesses with the maximum capacity without using cpu processing, only that when trying to do this it stops and informing that the internet is not fast enough for the operation. That’s right with only one access. monitoring the server, it says that it is in 9mb of use and the output of the internet in 6MB well below the total available output.
What am I doing wrong that I’m having this problem?
do I need to make any adjustments on the server and / or the plex client so that this does not happen?
in the client I put maximum quality and enabled the option to lower the quality according to the connection, both on the client and on the server.
I await the help of you with more experience to try to solve this problem, thank you.
This topic was automatically closed after 90 days. New replies are no longer allowed.
