Progam guide information in New Zealand (NZXMLTV)
Yep, I just ran an update, and now there is data up until the 6th of July (the 6th seems to be blank in the app).
Thanks again for your super fast response and fix.
Just tried your guide @shea9872 in the iptv app I use thanks! Any ideas why I don’t get listings for Three? Cheers
Seems to be working fine for me. What IPTV app are you using? I might see if I can replicate the issue
Hmm interesting, I also tried the epg from matt huismans website as well, and three was missing as well. I use tivimate app (android tv). I might test it in kodi and see what happens
I’ll take a look at that app, but I’d imagine if there was an issue with the guide, then Matt Huisman’s will also not work, as his is now based on NZXMLTV (just with some adjustments to work with his playlists).
No worries, thanks mate. I will see if I can figure it out
Yeah, I can’t seem to replicate it. Using Matt’s playlist and NZXMLTV it seems to show up fine
Ok thanks, good to know it work in there!
I see you are missing Duke and Choice, where as its fine in mine
Yeah, I’m wondering if TiviMate has an issue with automatically mapping the guide to the IPTV playlist? Because it seems a bit weird that some channels would show for me and not for you (and vice versa) otherwise.
Yea definitely weird
I just entered your epg into the GSE iptv app on my phone, and it lists all the channels and the data, BUT Three is not even on the list. ThreePlus1 is there but not Three @shea9872
These generally sound like issues with those individual apps. One possibility is that you could try the ‘lite’ versions of the Freeview guide (https://nzxmltv.com/freeview/freeview-lite.xml), this has the same data, but with a bunch of the ‘extras’ removed.
No luck with that, epg totally empty. But thanks for all your help
@shea9872 Holy, that’s amazing. The ■■■■■■ opentv guide that SkyTV makes is awful. I’ll give this a go. The main issue with the opentv guide is it doesn’t have episode number data so you can’t series record. Looking forward to checking this out.
I’ve tested it. It’s much better than OpenTV. There’s still issues with series record but overall it’s a massive improvement. Like for instance when I try to record just the Live Super Rugby Aotearoa fixtures, you can’t unless you record about 5 extra replays/highlights. No biggy I will just delete them as I see them.
I just wish there was a keyword auto record search within Plex.
Is there a problem with the Sky guide? There’s no programmes for ESPN and the other channels only have about a days worth of programme
Edit: Looks like there is an outage :frowning: . https://nzxmltv.statuspage.io/
Sorry about the delay in getting that sorted. It’s been fixed now
Thanks shea!! ::
