PS3 - "No Media Servers Found"
Help! :)
Trying to take advantage of the new PS3 plex player but could really do with a bit of expert advice!
I cannot seem to get the PS3 player to connect to my server and keep getting hit with "No Media Servers Found - Upgrade these servers to 0.9.10.1"
Running Plex version 2.3.20
I have tested the server/NAS is running correctly via the Android App. I can access media both via my WiFi and also externally from my network over mobile data.
Here is the odd bit...
Using the DNLA feature on the PS3 I can see and browse the Plex server! So it seems like its just the App/Player which is too blame?
This a known bug with the PS3 player? Anyone seen similar?
What version of Plex Server are you running, the version you gave (2.3.20) is the Plex\Web version. Look at Settings -> Server -> General to get the PMS version.
Also in the settings at Settings -> Server -> Connect, do you have the 2 green check marks to signify connection to Plex.tv servers? This is required.
Turns out issue is running on XP still so don't have correct sever version!
Thanks for the help though :)
Yeah, that will be a problem as even with plexpass you are stuck at 0.9.9.16 I think. Time to think about an OS switch. :)
