PS4 menu problem
Sorry if this gets posted in the wrong place, first post here! My issue is with the ps4 using Plex. I have various genres of movie folders set up & TV shows as the last entry in the menu run range. My problem is when I scroll down to access the TV shows, it won’t highlight it & stops at the previous menu. I’ve tried uninstalling & reinstalling but to no avail. I haven’t done anything different, this issue has just happened! I can access on deck items but have no way to gain access to browse the TV show menu. Any help will be much appreciated!
I’m having the same problem and it started today.
Same here. This bug was my fault. We just pushed another update which fixes the bug. Once you restart your PS4 app you’ll get the updated Plex app with the fixed bug. Apologies!
Brilliant response, thanks for everyone’s input, I’ll look forward to the update when I get back from work
