Server Version#: 1.24.4.5081
Player Version#: 4.63.0
QNAP TS670 pro 4gb ram current firmware 4.3.6.1750
Issue:
When the plex server is running the qnap is constantly dropping packets on both interfaces. If I stop the plex service it returns to normal.
Can anyone offer any help in fixing this?
Just reinstated the bond with fixed gw but that has thrown pms as I cant open the plex admin page as the browser seems to be in redirect loop, so just restarted to see if fixes it.
Results;
new library didn’t start as no tmp dir was created in the new library
manually mkdir tmp
now starts okay
Added in the same folder of home movies I had before and it is stable with no loss of pings!
Spoke too soon, overnight it has started dropping packets again
PING 192.168.103.131 (192.168.103.131): 56 data bytes
64 bytes from 192.168.103.131: icmp_seq=0 ttl=64 time=0.370 ms
64 bytes from 192.168.103.131: icmp_seq=1 ttl=64 time=0.251 ms
64 bytes from 192.168.103.131: icmp_seq=2 ttl=64 time=0.238 ms
64 bytes from 192.168.103.131: icmp_seq=3 ttl=64 time=0.266 ms
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
64 bytes from 192.168.103.131: icmp_seq=8 ttl=64 time=0.292 ms
64 bytes from 192.168.103.131: icmp_seq=9 ttl=64 time=0.247 ms
64 bytes from 192.168.103.131: icmp_seq=10 ttl=64 time=0.276 ms
64 bytes from 192.168.103.131: icmp_seq=11 ttl=64 time=0.242 ms
64 bytes from 192.168.103.131: icmp_seq=12 ttl=64 time=0.248 ms
64 bytes from 192.168.103.131: icmp_seq=13 ttl=64 time=0.248 ms
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
64 bytes from 192.168.103.131: icmp_seq=18 ttl=64 time=0.286 ms
64 bytes from 192.168.103.131: icmp_seq=19 ttl=64 time=0.248 ms
64 bytes from 192.168.103.131: icmp_seq=20 ttl=64 time=0.235 ms
64 bytes from 192.168.103.131: icmp_seq=21 ttl=64 time=0.320 ms
64 bytes from 192.168.103.131: icmp_seq=22 ttl=64 time=0.276 ms
64 bytes from 192.168.103.131: icmp_seq=23 ttl=64 time=0.283 ms
Request timeout for icmp_seq 24
64 bytes from 192.168.103.131: icmp_seq=25 ttl=64 time=0.306 ms
64 bytes from 192.168.103.131: icmp_seq=26 ttl=64 time=0.259 ms
64 bytes from 192.168.103.131: icmp_seq=27 ttl=64 time=0.300 ms
64 bytes from 192.168.103.131: icmp_seq=28 ttl=64 time=0.289 ms
64 bytes from 192.168.103.131: icmp_seq=29 ttl=64 time=0.309 ms
64 bytes from 192.168.103.131: icmp_seq=30 ttl=64 time=0.313 ms
64 bytes from 192.168.103.131: icmp_seq=31 ttl=64 time=0.241 ms
64 bytes from 192.168.103.131: icmp_seq=32 ttl=64 time=0.284 ms
64 bytes from 192.168.103.131: icmp_seq=33 ttl=64 time=0.246 ms
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
Request timeout for icmp_seq 36
Request timeout for icmp_seq 37
64 bytes from 192.168.103.131: icmp_seq=38 ttl=64 time=0.284 ms
64 bytes from 192.168.103.131: icmp_seq=39 ttl=64 time=0.210 ms
64 bytes from 192.168.103.131: icmp_seq=40 ttl=64 time=0.233 ms
64 bytes from 192.168.103.131: icmp_seq=41 ttl=64 time=0.280 ms
64 bytes from 192.168.103.131: icmp_seq=42 ttl=64 time=0.218 ms
64 bytes from 192.168.103.131: icmp_seq=43 ttl=64 time=0.315 ms
Request timeout for icmp_seq 44
Request timeout for icmp_seq 45
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
64 bytes from 192.168.103.131: icmp_seq=48 ttl=64 time=0.253 ms
64 bytes from 192.168.103.131: icmp_seq=49 ttl=64 time=0.238 ms
64 bytes from 192.168.103.131: icmp_seq=50 ttl=64 time=0.258 ms
64 bytes from 192.168.103.131: icmp_seq=51 ttl=64 time=0.189 ms
64 bytes from 192.168.103.131: icmp_seq=52 ttl=64 time=0.265 ms
