Server Version#: 1.14.0.5470
Player Version#: 3.71.1
I am having problems with Plex keeping my Remote Access enabled on my QNAP NAS. I get the Remote Access to work and within a few hours/days I get a message that I do not have a direct connection and playback is limited through a indirect connection. My NAS has two IP addresses: one that is connected to my router and has access to the internet and the other IP address is 10 Gbe connection directly connected to my main PC which does not have internet access.
Sometimes when I get the indirect connection error message it is because the Remote Access IP address has changed to the 10 Gbe connection, and other times the IP address stayed the same but the port has changed. I have tried to manually specify a public port but I have not been able to get that to work.
Any suggestions on how to get this to work would be greatly appreciated.
My QNAP NAS is connected by an Cat 7 ethernet cable to Wi-Fi router and my PC is connected over Wi-Fi to the router also. Additionally, I have a Cat 7 ethernet cable that is connected straight into a 10 Gbe port on my QNAP NAS speed to achieve faster transfer speeds.
Over the last few days, I have been unable to establish Remote Access. No matter what I try the port always goes to 0 instead of an actual port number. When I try to manually specify a public port it goes fully green for one second and then turns to red. Please advise what I am doing wrong.
