since a frew month I can not stream movies from my Plex Media Server anymore!
There must happen an unknown event that has to be the reason for that.
Befor that problem I could stream every movie from my Plex Media Server without any issues from every client.
It looks like a general problem.
I red some forum entrys about this mistake but haven´t found a solution.
Here is my setup:
Plex Server - (QNAP TS-451) Intel Celeron Dual Core 2,4 GHz (might be 64 bit)
Plex Client - Windows 10 - 64 Bit - (Opera Browser Version 50.0.2762.67)
Plex Client - Samsung - Smart TV
QNAP OS 4.3.3.0229
Plex Server Version 1.10.1.4602
Plex Web Version 3.27.1
I downloaded and manually installed the newest Plex Server Version (QNAP Intel 64 Bit) form Plex homepage.
“PlexMediaServer_1.10.1.4602-f54242b6b_x86_64.qpkg”
Can you help me solve this problem?
For a analyse I attached a screenshot and logfile from the Plex Server if the problem occurred.
If you want, I can deliver you a verbose logfile.
I took a look at log file “com.plexapp.agents.opensubtitles.log” and found an “error”.
In the log file it begin at line 19 but I don´t understand this log.
2018-01-23 16:32:57,845 (7fdc92e5b700) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes’
2018-01-23 16:32:57,912 (7fdc92e5b700) : ERROR (networking:219) - Error opening URL ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes’
2018-01-23 16:32:57,918 (7fdc92e5b700) : CRITICAL (runtime:1299) - Exception getting hosted resource hashes (most recent call last):
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py”, line 1293, in get_resource_hashes
json = self._core.networking.http_request(“http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes”, timeout=10).content
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 265, in content
return self.str()
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 243, in str
self.load()
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 181, in load
f = self._opener.open(req, timeout=self._timeout)
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 444, in open
response = meth(req, response)
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 557, in http_response
‘http’, request, response, code, msg, hdrs)
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 482, in error
return self._call_chain(*args)
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 416, in call_chain
result = func(*args)
File “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 565, in httperror_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp) HTTPError: HTTP Error 404: Not Found
ChuckPA commented about how you shouldn’t use the inbuilt multimedia, but create separate folders
The goal is to use /share/movies and /share/tv directly. Be completely free and clear of both Multimedia (which is an App-controlled share) and the CodexPack app itself.
Look at the above link and scroll down to the solution it might resolve your problem
thanks a lot for your post. You helped me sloving my playback problem !!!
I haven´t understand everything they discussed about in the entry you post but it helped me finding my problem.
With a closer look in the Plex Media Server “Playlist” I found wrong “media library” entrys!
For example:
This entry was wrong and I hadn´t set it up in the past:
/share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV4_DATA/HDD3/Movies 2/Musik Videos
I deleted it and setup a new one:
After that I could watch every movie from now.
I´m not shure but may be the installed QNAP “CodexPack” changed this entrys while I updated it in the past.
I learned that the “CodexPack” is not needet for Plex! And I also do not need DLNA or the QNAP media library because Plex is using his own! (good to know)
In this case I deinstalled the CodexPack and deactivated the DLNA Server and QNAP Media Library.
Hope you guys can learn from my fault. ; )
Thanks and Greetings Mr_NoGood
