Question on auto collections
How do you get Plex to automatically make collections based off of TMDB? I have it turned on and its not doing it.
Also, does the new updated Plex agent/scanner create auto collections? If so, how do I turn that on??
after setting you will need to refresh metadata for library
if using new Plex Movie agent then you need to select a number for Minimum automatic collection size 1-4
If you have “Prefer local Metadata” enabled for new agent or Local media asset for old agent it will also treat the embedded ALbum tag in an MP4 as what to set at the collection for that item.
