Auto update worked perfectly.
The only thing after the update it lost the connection to my plex and I had to reconnect to myplex again by logging in.
Extras & trailers are working flawlessy.
Thank you :D
Where do you find how to "Auto update"?
TIA
Thank you :D
TIA
Hi guys
I did the update to 0.4.1 and its is awesome and quicker, but I cant play youtube through it, which I managed quite well before updating!! any ideas? :huh: Keeps saying "Playback failed, one or more of your videos failed to work/play"
thanks
Anybody noticing the screen saver automatically disables after X amount of time?
My screen will dim, as per the defined settings, but then will randomly brighten a couple or so minutes later without any UI interaction from the user.
So far everything works fine for me! Saw the menu item to update and restart. I did notice a couple of weird permissions errors on a mv command in the boot startup but it kept on going and updated. The Extras feature looks awesome.
I had the same errors but everything seemed to work ok after it finished and rebooted.
Thanks for all the hard work Rasplex team! Looking forward to the full release.
I've never noticed this, and I normally leave RasPlex running 24/7. Most of the time I use the Fanart screensaver mode, and this is always still running when I return to the TV (whether still running or after I turn it on). Previously I mostly used the 'Dim' mode, just like you do, and I never had the problem you describe with that mode either.
I think the problem you see may be due to some spurious interaction packet from whatever unit you use to control RasPlex.
I use a very reliable USB-RF connected mini keyboard that never gives spurious packets, which is why I never see this.
But I have other keyboards which would do it all the time, due to bad coding in their internal programs.
And if you use CEC control through your TV remote and TV set, then you are also subject to features and bugs of their coding.
Some spurious packets intended to check continued connectivity could very well trigger the screensaver as incoming user input.
And if you have any mouse connected to your RPi (for use in Linux or whatever), then all kinds of vibrations may cause the mouse to send packets too. This may also seem spurious, but is really correct, since even slight air vibrations and sounds may cause single-pixel movement detection in a modern high-def mouse, which should result in movement packets sent.
Best regards: dlanor
Figured it was either the CEC control as that is the primary control that I use. However never noticed this behaviour before this build using the same setup.
I'll play around with the screen saver settings a little. There is no mouse or keyboard connected, just the CEC control and iOS devices when they are connected.
Thanks for the release!
Finally Hi10 really start transcoding (for me), unfortunatelly after a few minutes/seconds of playback i get only green screen with ocational blue and yellow and red flashes until i perform jump in the movie - than it plays ok again, but tat is probably issue with transcoder.
Finally updated to a 1080p tv (yeah, finally). Excited to finally be able to use 24,25 and 30 hz modes. However, it seems to have some issues detecting this on boot up. Half the time only 60/50hz is available. I'm feeding it through a receiver that is getting a bit glitchy lately, so that could be the culprit. Don't know it anyone else has this problem, so I'm putting it out there. Apart from that everything seems great.
Just updated to 0.4.1 via auto update and HDMI CEC is not working anymore.
Any tipps?
Checked the CEC settings with a keyboard and everything seems to be fine. No clue. Just 2 hours ago CEC worked very well with 0.4.0-RC4.
Note: Similar issue with 4.1 using HDMI to DVI adapter and PC monitors. With 4.0 I see rainbow and get full boot/functionality on Monitors and TV. With 4.1 I do not see Rainbow on PC monitors (tested 4:3 and Widescreen) and screen remains black (backlight comes on), but works fine on TV with HDMI. Appears to be a pre-boot issue with 4.1.
Love 4.1, thanks for the update. I had been using PlexIT to get movie trailers for my wife but now AMT works again and I get trailers in the movie selection. Still missing FF and RW but can live without it. Thanks guys for all the hard work!
Keith
Can you SSH in to your Pi and enter:
tvservice --modes=CEA when its connected to you Monitor and report the output.
Regards
Hi guys
thanks
Have just installed YouTube, all videos play fine, suggest using Plex Web to Uninstall and then Reinstall.
Regards
I give it a try and get back to you
Thanks for the post NedtheNerd, I tried it and it worked great, thanks. I don't know why I didn't try that in the first place, probably cause I installed it after the update I didn't think it was the install to blame. But thanks anyway.
I have a few files that have
x264 video codec
DTS or AC3 audio codec
And an extra audio track (commentary) with HE-AAC codec
Plex web, PHT for PC and PHT for rasplex fails to show any media info for these files and Rasplex will not play them
It is defiantly something to do with the HE-AAC audio because this only happens on files that have this, ( took me a long time to find that out :mellow: )
Although PHT for PC doesnt show any media info it manages to play them.
Any ideas ?
So files with HE-AAC as commentary do not work but files with Vorbis as commentary do work.
There is an example of both below
Was running rc4 and could direct stream Blu Ray Rips directly with no issues using an external receiver for DD and DTS with HDMI to a 1080P TV.
Auto Updated to 4.1 which went very smoothly, however cannot play my 2 standard 1080P test movies. (Avatar and The Dark Night, first uses AVC and the later uses VC-1) as they stutter. Dropped back to rc4 and all is fine.
The Pi's are overclocked and I do have the Night Skin loaded which should not affect the actual playback.
Thanks dlanor, I should have tried with the Plex skin as an engineer I should know better than trust the "it shouldn't make any difference" way of thinking :-)
I have the following in my config.txt
hdmi_force_hotplug=1hdmi_drive=2gpu_mem_256=64gpu_mem_512=200gpu_freq=350arm_freq=950core_freq=450sdram_freq=450over_voltage=2CPU shows pretty much maxed out at 100% when playing either The Dark Night or Avatar
In order for me to playback BluRay's I had to set it to maximum over clocking!
