RasPlex and Subtitle add-on
In XBMC there is a add-on for the download of subtitles.
When I switch RasPLEX to the OpenElec mode and look for a Add-on it does not show one.
Is their a way of getting the some of the Add-on's in RasPLEX or do I need to go back to Plexbmc, I hope not as RasPLEX has a more 1:1 interface to Plex on my Mac.
thanks,
I have not found a solution it does not seem that I need a solution.
For some strange reason Plex downloads the subtitles  :mellow:
I'm wondering is the a backed in tool of RasPLEX or is it the PLEX server that is doing this <_<
It would be nice to know.
It should be the PMS . Thus, subtitles might not be available if direct-play is enabled.
Dear Plex Ninja,
Where can I control the direct-play setting in the PMS? Or is this a setting in the Rasplex client? Thanks in advance
Direct-play or transcoding is a client (not a PMS) setting.
You may try to enable the “force-tanscoding” option within the settings but this may require a powerful PMS…
There is currently no good solution available. You should create a feature request at the PlexHT forum to get this feature into PlexHT (and thus RasPlex too).
