Recent poor performance and poor video quality
I have Plex running on a Windows 10 pro machine for a year. I would say in the past couple months things have really degraded in performance and streaming quality both local and remote. My home network has not changed and cant seen to figure out what the issue is. I even went so far to reinstall a fresh installation of windows and PMS install and it had no affect. I have searched and tried many things on here from optimization to transcoding tweaks to windows settings (Large Send Offload). No change. Utilization is in the 2-3% on Intel Core i5-7260U CPU. I am stuck, any help would be extremely thankful.
Windows 10 Pro
Server Version#: 1.18.3.2156
Fire TV 7.25.2.14287 Plex for Android (TV)
Chrome 4.18.1 Plex Web
is it happening on all video types played or just certain files,
does it happen on direct stream/play or just when you transcode?
is your pms on a laptop?
im assuming your network is working over wifi are there more devices recently, did you change your wifi channel?
seems weird if nothing changed but quality dropped so im assuming something changed or its a hardware issue.
video degradation is across the board on all files, If i select play original or a transcoded quality it also performs the same. PMS is on a NUC desktop that is hardwired with internet test speeds 100mbs/120mbs (down/up)
It’s possible that your clients are being relayed through plex.tv if they think they can’t reach your server directly.
Can you post a screenshot of the Now Playing section of the server Dashboard while playing a video on a client not on your PMS/NUC.
This is Dashboard while playing a movie on my FireTV on local LAN streaming in original quality
Yes, and I’m looking for the Now Playing section which is above the performance graphs, it will look something like this:
2 posts were split to a new topic: Poor video performance
FireShot Capture 001 - Plex - 127.0.0.1
Here is mine
@ryanbrichards it seems like you have an indirect connection to your server – the 2mbps stream rate usually indicates your video stream is being relayed through plex.tv.
This could be a DNS issue
or
DNS rebinding protection
  1. set the DNS server to the one provided by Google (in your router) (8.8.8.8 and/or 8.8.4.4)
  2. disable DNS rebinding protection for the domain plex.direct (also in the settings of your router)
My router was set to ISP DNS, i use a google wifi connected to a switch and changed it to Auto (8.8.8.8) not sure there is a setting to disable DNS rebinding protection other that specify a specific DNS
Changed DNS and here is new stream
FireShot Capture 001 - Plex - app.plex.tv
and here is another one when selecting “covert auto” on FireTV, picture quality terrible
I’m not familiar enough with that client to know what the best settings are for playback… but it seems like you’re closes; I’m going to re-tag this thread with android tv in the hopes that someone else will be able to help out.
