can anyone help me to force a manual update?
I would like to upgrade my OpenPHT running on Raspberry from 1.6.2 to 1.7.1 so I’ve swithced the update channel to pre-release, checked for update and also downloaded it. Forced a reboot but nothing has happened. The new image is in /storage/.update folder (checked via SSH). This documentation says "To install updates, (either manual or automatic), go the the Home screen and select ‘Install update’ " but I can not find that option. So how to install that update?
Thanks in advance for your help.
@driekes said:
I’m using OpenPHT for quite some months happily! There is however one issue, that is the ratings of RottenTomatoes. It is always displaying 0%.
I’m using the Plex Movie agent
I do not have another agent that is collecting ratings
It does display on Plex Web
Library scanner ratings source is set to Rotten Tomatoes
What could be the cause?
what version openpht and which skin are you using?
Is openpht still alive? Is it being developed or its in hibernation mode? Can I help with a donation? I really love your work and I can’t stand pmp (and similar Netflix UI copycats… whoever though that was a good idea only god knows) so my only hope and salvation is openpht
its still alive simply we are limited by the time the developer can spend on it, of which alot is required. i have personally tested atleast 10+ versions of openpht since the last official release, the next release should be soon.
there is quite a bit going on in the next release, it has alexa and based on LE8 for embedded versions etc among quite a few other things, it just takes time. i would expect that next release to be a matter of days, not weeks at this point
