Remote Acces don´t work
I had a Synology Ds918+ with Plex server running. I had setup uPnP on the box and the router (Asus RT88U) has enable the port forwarding. I can see the list of ports in the router. I am using 32400 (standard). But I can´t get it works with remote access :frowning: I had reset the Asus router. But it don´t help. NB. I am running with static IP on the wan interface. What am I doing wrong?
Dear Andy M.
I had fix it. After I had talk to the ISP and the ISP has reset the line. And I also reset the Asus router and when the Synology box, it works. :-).Now the remote access is green.
