I have looked at your logs
None of the connectivity tests from our back end systems got through to PMS
I see you have loads of network adaptors
Which one is the port forward to ? and was the port forward still in place at the time
The following would be relevant if the port forward was to 192.168.3.109:
- At 15:44:25.587 April 13th one of the network adaptors dropped out - 192.168.3.109
- At 15:44:31.143 April 13th came back with a different IP address 192.168.3.106
Is the port forward to another IP address ?
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - Network interfaces:
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 15 br0 (192.168.3.109) (loopback: 0)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 16 docker0 (10.0.5.1) (loopback: 0)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 17 lxcbr0 (10.0.3.1) (loopback: 0)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 18 qvs0 (192.168.3.2) (loopback: 0)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 19 qvs1 (192.168.4.1) (loopback: 0)
Apr 13, 2020 09:03:55.927 [0x7f2277ef7740] DEBUG - * 18 qvs0 (fe80::265e:beff:fe0f:9e97%qvs0) (loopback: 0)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - Network interfaces:
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 16 docker0 (10.0.5.1) (loopback: 0)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 17 lxcbr0 (10.0.3.1) (loopback: 0)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 18 qvs0 (192.168.3.2) (loopback: 0)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 19 qvs1 (192.168.4.1) (loopback: 0)
Apr 13, 2020 15:44:25.587 [0x7f22656cb700] DEBUG - * 18 qvs0 (fe80::265e:beff:fe0f:9e97%qvs0) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - Network interfaces:
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 15 br0 (192.168.3.106) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 16 docker0 (10.0.5.1) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 17 lxcbr0 (10.0.3.1) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 18 qvs0 (192.168.3.2) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 19 qvs1 (192.168.4.1) (loopback: 0)
Apr 13, 2020 15:44:31.143 [0x7f22656cb700] DEBUG - * 18 qvs0 (fe80::265e:beff:fe0f:9e97%qvs0) (loopback: 0)
Connectivity Tests at these times did not reach the server
Apr 13, 2020 09:04:15.321 [0x7f2267466700] DEBUG - EventSource: Got event [data] '<Message address="101.118.xxx.xxx" port="32400" asyncIdentifier="661f5752-fb44-4ef8-a7d8-c04ca7d0c987" connectivity="0" command="notifyConnectivity"/>'
Apr 14, 2020 09:04:07.371 [0x7f2267754700] DEBUG - EventSource: Got event [data] '<Message address="101.118.xxx.xxx" port="32400" asyncIdentifier="c0a4d537-55cf-46c4-93bc-1c8947a60ec3" connectivity="0" command="notifyConnectivity"/>'
Apr 14, 2020 18:45:27.936 [0x7f2267754700] DEBUG - EventSource: Got event [data] '<Message address="101.118.xxx.xxx" port="32400" asyncIdentifier="f3547f15-ef14-4c14-8be3-ed0c7d0aa7fa" connectivity="0" command="notifyConnectivity"/>'
When you have this problem - can you test the port forward with an attempt to connect to your server from outside - like this:
http://public-wan-ip:32400/web
If you get to an authentication challenge it means that the port forward is ok
But the test needs to be from outside your network as some routers block attempts to connect through the WAN IP address when on the local network
