Server Version#: 1.27.2.5929
The remote access is green, but the server is shown as offline on devices outside my home network.
Isn’t using port forewarding, but got UPnP enabled on my router.
Are using 2 routers, not bridged.
When my phone (S22 Ultra) is on the same nettwork, I can see every movie and show, but nothing when i turn off the WiFi. Both through the app and web browser.
Logs are attached.
Plex Media Server Logs_2022-07-13_18-17-07.zip (3.2 MB)
tom80H
July 13, 2022, 4:29pm
2
Your logs will only cover a small faction of the components involved in your remote access setup.
Did you already have a look at the related troubleshooting support article?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
There’s also a guide with some more details on how to address remote access issues:
When it comes to remote access, there’s a lot of different factors which can impact your setup. Some are under your own control, others not so much.
First off… there’s a dedicated support article on troubleshooting your remote access . I strongly recommend you have a look at that.
Find below some additional remarks on how to troubleshoot your remote access setup.
Review your internet access / remote access configuration
It’s good practice to review if Plex gets the correct public IP address…
You’re in a double-NAT situation:
Jul 13, 2022 13:53:52.237 [29024] ERROR - [EventSourceClient/pubsub/172.105.64.14:443] MyPlex: mapping failed due to potential double NAT configuration
Jul 13, 2022 13:53:52.238 [29024] DEBUG - [EventSourceClient/pubsub/172.105.64.14:443] MyPlex: mapping state set to 'Mapped - Not Published (Double NAT)'.
Review the documents @tom80H linked.
Some possible options:
Option: Place one router into Access Point mode
This eliminates one of the NAT functions.
Compatible with both UPnP and manual port forwarding.
Option: Double Port-Forward
Requires manual port forwarding. Incompatible with UPnP.
More difficult to implement and troubleshoot.
Fallback option if unable to place a router in Access Point mode.
Option: Plex Relay
Fallback when Remote Access unavailable due to double-NAT, CG-NAT, etc.
Streams tunneled through servers at Plex.
Limited to 2 Mbps (1 Mbps if server admin does not have Plex Pass).
