Remote Access keeps disconnecting
So lets wait for the disconnection and get the logs and check the event logs - do also check system and application event logs
definitly is some problem of pms… it was working with previous version … and not now… hope a new release comes soon to fix this… and its not only me that has this problem… so must be some bug…
we can talk about it but that will not help identify the problem. We have to wait until you have the disconnection and see what the diagnostics show
i found another strange thing… it disconected again… but who was wathing movie can acess normaly pms … but a new user if tryes to connect it cant… very strange… send the log of a new disconnect…
now its worst…it cant let me siggn in…
It does not look good
Lots of time outs on internet connection - perhaps you are overloading the network / router.
Aug 17, 2015 18:54:07:010 [4664] ERROR - Error issuing curl_easy_perform(handle): 28
Aug 17, 2015 18:54:07:010 [4664] WARN - HTTP error requesting GET https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/access_tokens.xml?includeProfiles=1&auth_token=xxxxxxxxxxxxxxxxxxxx (28, Timeout was reached) (Operation timed out after 90312 milliseconds with 0 out of -1 bytes received)
Aug 17, 2015 18:54:07:010 [4664] DEBUG - Simulating 408 after curl timeout
Aug 17, 2015 18:54:07:011 [4664] ERROR - MyPlex: Error 408 requesting XML from: https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/access_tokens.xml?includeProfiles=1&auth_token=xxxxxxxxxxxxxxxxxxxx
Aug 17, 2015 18:54:07:011 [4664] ERROR - MyPlex: Couldn't get list of access tokens from myPlex.
Aug 17, 2015 18:54:07:011 [4664] DEBUG - EventSource: Failure in IdleTimeout (0 - A operação foi concluída com êxito).
Aug 17, 2015 18:54:07:011 [4664] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Aug 17, 2015 18:54:07:011 [4664] ERROR - EventSource: Retrying in 15 seconds.
Aug 17, 2015 18:54:07:011 [4664] DEBUG - EventSource: Got event [data] '<Message command="notifySharingChange"/>'
I will and try and pick all the timeouts
but same users on the previous version and everything was ok… never happened this before… i have 400mega download and 45 uplod… never had this issue…
Can you demonstrate that with logs showing same load level on the old version ? You would lose iOs access whilst performing these tests?
only have ios produtes… iphone and ipad…and all updated to v4… even if i roll down to version Plex-Media-Server-0.9.1117.986-269b82b i have no means to test it…
I will go through the logs you supplied and pick all the network timeouts to understand which fail and they fail repeatedly
Thanks… Do you think it could BE the internet router? I remember that i restarted it before updating… And i didnt restarted the router for Many months… Maybe the router Make sabe kind of update?
possible. I will establish what was failing and when and how frequent
Thank you for your time… And for your patience…
new log out…here is the log…
I am sending you a request i would like you to time to see how long it takes - just wondering if the number of shares (160+) is a factor on timeouts when getting list of access tokens
but i had this working with this shares in previous version and no problem at all…
Please we are only investigating at the moment. No conclusions yet.
To summarize the current position:
The server logs show a number of timeouts on requests to plex.tv - most being for the list of access tokens. The size of this access tokens xml is about 100Kb due to the high number of shares - about 160 - a level that is way above what a user is expected to have in terms of shared libraries and access tokens
There was also evidence of other timeouts on smaller requests.
The plex.tv logs are being checked to see if there was an issue but so far there is no evidence of a problem on the plex.tv end
The server logs do show a heavy load of remote streaming and also sync activity. It would be worthwhile assessing how much remote syncing is being done. The xml from this request will list all sync requests
https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/sync_lists
An example of the timeouts showing in the log:
Aug 17, 2015 17:55:59:685 [4556] DEBUG - HTTP requesting GET https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/access_tokens.xml?includeProfiles=1&auth_token=xxxxxxxxxxxxxxxxxxxx
times out
Aug 17, 2015 17:56:30:364 [4556] ERROR - Error issuing curl_easy_perform(handle): 28
Aug 17, 2015 17:56:30:364 [4556] WARN - HTTP error requesting GET https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/access_tokens.xml?includeProfiles=1&auth_token=xxxxxxxxxxxxxxxxxxxx (28, Timeout was reached) (Operation timed out after 30671 milliseconds with 0 out of 0 bytes received)
Aug 17, 2015 17:56:30:364 [4556] DEBUG - Simulating 408 after curl timeout
Aug 17, 2015 17:56:30:364 [4556] ERROR - MyPlex: Error 408 requesting XML from: https://plex.tv/servers/bad34591faef8a01fb210d75523b54e03e490575/access_tokens.xml?includeProfiles=1&auth_token=xxxxxxxxxxxxxxxxxxxx
Aug 17, 2015 17:56:30:364 [4556] ERROR - MyPlex: Couldn't get list of access tokens from myPlex.
It may be worthwhile to enable verbose logging for a short while on the server to see if time taken to download the access_tokens is logged - when it does not timeout (Settings/Server/General/ Verbose Logging)
@PLEXHOME01 - please could you also add to this thread the logs you PM’ed me today and a short note to say what action you took and when and when did you notice the problem and why you believe there was a disconnection when the logs you supplied showed a remote iPAd having a connection to the server a few seconds before you shutdown the server
@PLEXHOME01
if you do not stop spamming all remote access threads - i will stop looking into your issues
