Remote Access Not Available, Yet It Is
Server Version#: 1.42.2.10156
Player Version#: N/A
I recently switched ISPs. PMS says Remote Access isn’t available, yet it works just fine. Is there anything I should be doing to have this appear correctly? I’m not sure it ever did with the old ISP, but having wholesale switched everything over, I was curious.
Same WiFi, different modem/provider. Ports remain forwarded as they were before, and everything has been power cycled. This is 24 hours later.
@AmazingRando24
Do you have GeoIP blocking enabled?
These IPs must be allowed in. These IPs are the “Remote Access” testing servers.
Their sole purpose is to open the port you’ve specified and say “hi” to your PMS.
When that happens, your PMS gets happy and stays green :slight_smile:
https://s3-eu-west-1.amazonaws.com/plex-sidekiq-servers-list/sidekiqIPs.txt
( I have IP filtering. Without these on my access list, I look like I’m offline )
Appears to have done the trick, @ChuckPa, Thanks!!!
