Remote access not working - though says it is in PMS
Plex Media Server Logs_2019-06-26_13-47-27.zip (4.5 MB) Server Version#: Version 1.16.0.1226 / Readynas Ultra 2, OS 6.10.1
Player Version#: various: IOS 5.16.1; PLEX for Android 7.16.1.10610
As per discussion in another thread - please, I need help!
Remote access had been working for me, then suddenly stopped - no firmware or software changes had been made on the server, network or players. (was not previously using Port Forwarding - just ‘Automatic’ Remote Access default setup)
I saw there was a new PMS version available, so I updated - no change.
Restarted Readynas and PMS - no change.
Replaced my gateway/modem (xfinity xfi) - no change.
Setup Manual port forwarding (enabled via the gateway [have screenshot] and done on PMS)- no change.
PMS shows that Remote Access is active. (have screenshot)
Port is verified to be open (have screen shot)
Spent lots of time on phone with Xfinity support - no firewall or other firmware/protocol changes on that end.
Tried deleting Port Forward on both and repeating. - no change.
I have downloaded the Plex log and am attaching it.
Please help!
Adam
@sa2000 : are you able to help out at all, please?
Do you have static IP and port forwarding setup in your router for your PMS?
I don’t have a “static IP” (it never moves/changes though) - but then I never did have and it always worked.Yes, I have port forwarding and have verified the port is open/setup in PMS as well.
IP address doesn’t change if the machine that the PMS is running on looses power or is restarted?
No - I’ve tried it a few times and seems to keep the same IP each time.
